Hi,
My friend just had Zen 500 FTTP installed and originally had Zen FTTC 70/20 and went through a regrade to move him over. He has kept all his external Ip's the same.
Unfortunately the speeds he is getting is right on the minimum guaranteed speed of 250Mbit. It's all over the place to be fair, one minute it's 350 the next its 150. I live a 10 minute walk from him in the same town and mine is 550 to 600Mbit without any issue.
He called Zen after some speed tests and they got us to connect a machine directly to the ONT and create a manual PPPoE connection which was still the same, best speed we got was 230Mbit. So I know the issue is not the local network (we also tried like 10 different cables on the advice of Zen, they even said that CAT6a was WORSE then CAT5e but I tried all different types)
Zen have basically said because he is getting the bare minimum guaranteed speed there is nothing they can do and he just has to live with it, even though he is paying for 500 and only getting (at some points) half of that if not lower between speed tests
I really don't know what else he can do apart from going back to them when the speed test is below 250 and saying it's below that minimum. This seems like a crazy situation, they don't seem to care if you hit that 250Mbit when you pay for double that??
I wondered if the engineer who performed the fibre splice messed it up, he didn't do the splice in a controlled area, it was done on the window-cill with his splicing machine in the open weather, either way this is crappy of Zen and I expected a much better response but I guess all he can do is leave during the cooling off period. This causes some issues as he needs the 5 external IP's he has and changing all that will become a right pain in the rear.
Any advice ? or is it just lump it?
