Don
- 20 Oct 2002
- Oxfordshire / Bucks
Perhaps I'm expecting too much! I'm new to foaming.
It did nothing to the front wheels either, should foam? I thought it would do a bit. Back wheels were ok, not much dust on them to start with.
Not sure on the ratio, I have a new pressure washer and it's a new foam cannon and I haven't timed it yet, so I just chucked some in.
oh right, ok, well i am guessing your ratios are all wrong for starters
HOW TO USE
TOUCH-LESS may be applied with trigger spray, pump spray, pressure washer, or snow foam lance. The minimum recommended dilution rate should be 2% PIR (Panel Impact Ratio) and up to 5% for very dirty vehicles. Where application is through trigger spray or pump spray, the dilution calculation is easy to achieve, however, for application with pressure equipment it is essential to determine the amount of water being delivered to the equipment reservoir.Step 1
Fill the detergent bottle or reservoir (on machine or lance) up to capacity with plain water. Turn detergent feed to full. Take a large bucket or container and discharge the lance into this, watching the detergent bottle until empty. Once empty, stop.
Step 2
The following calculations will achieve 4% dilution; Measure the total amount collected and multiply this number by 0.04 (Total can be measured in either volume with a measuring jug or by weight) this is the amount of TOUCH-LESS to use.
Step 3
Add the calculated amount from STEP TWO to the pressure-washer reservoir and top up to full with cold water and shake in for a few moments.
Step 4
Apply touchless to entire vehicle or panel by panel. Allow to soak for 1-5 minutes (but never allow to dry). Power-wash off.
It is not necessary to use all diluted touch-less in one wash. One litre of diluted product should last 4-5 washes. Apply to cool panels in shaded conditions. Do not allow this product to dry in use. Keep the bottle neck and lid clean.
