It's more disappointing not seeing the mid / lower tier sooner where most of the market is
Wow. I didn't know that, that's disappointing![]()
Even current AMD cards are about $100 overpriced for what they give, this is after all the holiday discounts... I won't name Nvidia because honestly they are like Apple, a toy for the rich...It's hard to get excited when AMDs 900XT only matches Nvidias ##80 in raster especially when Nvidias 80 is really a 70 and should be priced no more than £650.
few more sneak peaks at upcomming cards
XFX Radeon RX 7900 XTX and 7900 XT Merc 310 GPUs have been pictured - VideoCardz.com
XFX Speedster RDNA3 series XFX playing safe by using very similar design to RX 6000 series. The company's first custom cards for Radeon 7000 series havevideocardz.com
Sort of, yes and no. Yes in that it's a cut-down top-end chip, second from the top (at least initially). No in that its price is a lot closer to it's bigger brother than the 6800xt was to 6900xt. And there will almost certainly be a 7800xt based on a full-fat Navi 31, or a further cut-down Navi 33.I like this card, my 6800xt Merc has been a fantastic card.
Is the 7900xt the replacement for a 6800xt??
Thanks for thisSort of, yes and no. Yes in that it's a cut-down top-end chip, second from the top (at least initially). No in that its price is a lot closer to it's bigger brother than the 6800xt was to 6900xt. And there will almost certainly be a 7800xt based on a full-fat Navi 31, or a further cut-down Navi 33.
6700xt is definitely one tier above the 3060, so it's not a fair comparison.In fairness it depends on which tier your after. If you watch the lower end stuff a guy compared the 3060 with a 6700XT that he got for the same price. It destroyed it and shows the Apple part you mentioned can be squat all in some cases. You are simply being mugged for a brand name at that point.
TBH on AMD land the 6600 and XT are about 50€ too much, the cards above at least 100€ over what they should be.
7800xt and 7700xt are n32.Sort of, yes and no. Yes in that it's a cut-down top-end chip, second from the top (at least initially). No in that its price is a lot closer to it's bigger brother than the 6800xt was to 6900xt. And there will almost certainly be a 7800xt based on a full-fat Navi 31, or a further cut-down Navi 33.
On a somewhat related note, any word on how AMD is disabling chiplets to cut down their chip versions i.e. will it be done physically or through software? Likely optimistic, but has there been any hypothosis of rx290/6800/465 GTX vanilla unmasking magic?
Yeah I think if you compare the 6700XT to 3060ti and 3070 then that's fairer.
What AMD have done is change the names 6900XT > 7900XTX and 6800XT > 7900XT.Thanks for this
So basically AMD have created a new tier, a bit like it's CPU range.
The XFX card is interesting because it looks like the backplate is designed to function as a heatsink instead of just being decorative like it is on most cards. The silver colour would go nicely in my case too. Have to wait and see how much it costs relative to the reference design.few more sneak peaks at upcomming cards
ASRock preps liquid-cooled Radeon RX 7900 XTX AQUA graphics card - VideoCardz.com
AMD Radeon 7900 XTX GPU with water cooling The ultra-premium ASRock liquid-cooled series are now coming to GPUs. ASRock RX 7900 XTX Aqua OC is the firstvideocardz.com
