Don
- 20 Oct 2002
- Oxfordshire / Bucks
i do
ring ones are brilliant
Thanks for the info its good to hear first hand experience of a compressor, i'm still so undecided as i can't really justify spending more than 100odd quid on anything at the moment so i'd only be getting into the low end compressors which probably would be no good for air tools. I don't really have the space in the garage for a really big compressor or the money to buy it and to be honest so doubt i'd get a whole lot of use out of air tools as i already have a few battery ones and don't do as much car stuff as i used to so it'd pretty much just be for blowing up tyres and blowing stuff off, only thing which would be useful is one of those needle scaler things to chip off the **** from welding but as i think that's essentially an air chisel i doubt the smaller compressors would run one well?
Also thanks for all the other people recommending plug in inflators which i've said about 5 times i have no interest in
.Also thanks for all the other people recommending plug in inflators which i've said about 5 times i have no interest in
I got one of these, battery powered but can use cigerette charge it if dies out on the road..usually 30-35quid off the bay
im trying to compare it to this one
does your one auto shut off ?
do you know the time it takes to pump a wheel up from flat?
Alao, a new one on the bay is £50, the £35 one is used
Suggestions? I'm thinking stocking fillers for Christmas.Everyone should always have a ring compressor in the boot of every single car they own, they’re only £20 and can be a lifesaver. Trust me haha
This one.Suggestions? I'm thinking stocking fillers for Christmas.
True but I've ordered a couple of their cheapest automatic ones. That'll do nicely, thanks.It's not like you need anything fancy.
I can tell you the ring one has auto shut off and it works very well. It can also pump a Berlingo tyre up from dead flat in about 5 mins or maybe less as I wasn't timing it.im trying to compare it to this one
 www.vonhaus.com
					www.vonhaus.com
