Hi all - are Eco Heaters a good buy? Advertised a lot but are they worth it? Do they heat a room well & cheap to run? I can't help but think if as good as advertised would not everybody have one. Many thanks for any guidance.
Many thanks for the link. Shall report back once had a chance to listen. Thank you.Have a listen to this - https://www.bbc.co.uk/programmes/m001dxtx
Yes I keep hearing good things about oil filled radiators. Many thanks for your reply.I don't think there's such a thing as an eco heater. The lower the wattage, the slower you'll heat the room up.
I don't know if this still applies, but I always thought that oil filled radiators were the best way to properly heat a room up. Admittedly the room might take a bit longer to heat up than with a fan heater.
