 - 13 Apr 2013
 - Scunthorpe
Are you saying that 10gb of vram isn't enoughOn the bright side my 16GB Vram may not be enough now they have 24 GB.![]()
8GB Vram is enough only if you play FC6 without the texture pack.Are you saying that 10gb of vram isn't enough![]()
Just curious, does the gpu even have enough grunt for that regardless of vram?8GB Vram is enough only if you play FC6 without the texture pack.
Also no 5K RE2 with maxed RT.
Yes, yes it does.Just curious, does the gpu even have enough grunt for that regardless of vram?
Yes, yes it does.
It don't have enough Vram is the issue, surprisingly the overclocked 3070 was enough in that title at 5K if it had at least 9GB maybe LOL.
It slowed down in very specific areas and there was tiny stuuter hitching here and there whilst maintaining above 60 FPS.
Yes, yes it does.
 Let's change subject to Ray tracing!
Just checking my RE 2 footage with 3080 at 4k, performance was pretty good tbf so probably 5k be decent/playable as well:
IIRC, a patch or 2 addressed some of the performance issues especially when people enabled hdr @mrk was a fan of the game![]()
Still not getting it a year later.Let's change subject to Ray tracing!
	the ending was top notchFar Cry 6 is a bit of a rubbish game though.
Change my mind![]()
Lol HDR and black levels in that game were pretty poor but the performance was fine if you didn't enable HDR which resulted in weird stuttering, so if they've fixed that then I may give it another go but it was clear that res Evil 2 was the weaker PC port of the others when I played through them.
Nah it struggles with the HD texture pack in FC6, next gen pixels too high quality for the gpu
Obviously you needed more vram using somes logic here
We're talking about RE 2 remake, not fc 6.
Change my mind![]()
Same thing applies, vram too slow on that GPU, can't drive those HD 4D Pixels that Microsoft promised
Ignore the grey in the screenshot, that was from HDR mode and it isn't a tonemapped screenshotResident of Grey![]()
