1.06kwh today, booooo
I only did 2, was very hazy/misty most of the day.
Yes of course!Is anybody graphing savings based on real rates they would be paying for each unit generated for many years? Based on best pried tariffs etc.
Yes of course!![]()
Seems a good reason not to buy their products then.Ah FFS. Tuya have put their energy monitoring data behind a paywall.![]()
I need to do a bit of work as I've got various monitors - I've got my initial outlay and then the saving per day, week , month on electricity. I haven't done the saving on water heating yet - need to think about that.Who would have doubted it, no-one I bet!
Have you got a time to pay back count down display on your HA setup?
Christ, that looks like the day job.![]()
GitHub - rospogrigio/localtuya: local handling for Tuya devices
local handling for Tuya devices. Contribute to rospogrigio/localtuya development by creating an account on GitHub.github.com
Or install this, convert your tuya devices to local and connect to your home assistant instance and be free of it forever ...![]()
Perfect procrastination projectChrist, that looks like the day job.
Does solar panels work well when it's so cold as it is now but blue sky sun light?
If anything they work better when they are cold.
But usually cold weather= lower sun/sunlight.
If you could have end of June sunlight, and middle of December temperature it would be perfect
The angle of the sun is the biggest single factor.Yes. But as the sun is low in the sky they won't be generating as much as if the sun is overhead. You're also much more likely to get shading while the sun is this low.
6  | Aug-22 | 15h 07m 43s | 55.1° | 24.7  | 23.6 | 32.2  | 47155.5  | 55.8  | 80.5  | ||
7  | Aug-22 | 15h 04m 22s | 54.8° | 25.5  | 23.5 | 32.3  | 47181.0  | 55.8  | 81.3  | ||
8  | Aug-22 | 15h 01m 00s | 54.5° | 25.0  | 23.1 | 31.7  | 47206.0  | 54.8  | 79.8  | getting hotter every day | |
9  | Aug-22 | 14h 57m 35s | 54.2° | 23.3  | 23.2 | 30.1  | 47229.3  | 53.3  | 76.6  | ||
10  | Aug-22 | 14h 54m 09s | 53.9° | 23.7  | 22.9 | 31.2  | 47253.0  | 54.1  | 77.8  | ||
11  | Aug-22 | 14h 50m 41s | 53.6° | 24.0  | 22.9 | 30.9  | 47277.0  | 53.8  | 77.8  | and hotter | |
12  | Aug-22 | 14h 47m 11s | 53.3° | 23.4  | 22.5 | 30.2  | 47300.4  | 52.7  | 76.1  | ||
13  | Aug-22 | 14h 43m 40s | 53.0° | 23.4  | 22.4 | 30.3  | 47323.8  | 52.7  | 76.1  |
