How do i update to next gen? ive got it installed via GOG and theres no option.
GOG it just does nothing when i check for updates. Stuck on ver 1.32GOG or Steam?
Until they fix the performance issues with DX12, stay away. CDPR didn't even bother to include mod fixes for well-known bugs some of the incorporated mods had.
DX11 version runs basically 2/3 as good as the pre-patch version even if you had the same exact mods + other ones on top of them. Why ? Eh, who knows.
The DX12 one aka the version with the additions you couldn't get before has **** performance due to the usual complete lack of understanding of the library seen in previous high profile games, with the kind of performance highlighted by Rifle. It's not going to be magically fixed unless it has to do with a deep drivers issue - which I don't buy at all. Those constant stutters hint that something is amiss in that regard.
Curiously, console versions seem very well optimized and apparently run like a dream
I assumed that I would have to start a new playthrough for this new version?everything running fine for me. Already had a load of mods installed and only one that doesn't seem to be working is the inventory item weight mod.
I'm not sure it looks any different even with ray tracing though
Had a bit of a play this morning and have to say I'm impressed. There are some frametime stutters shown on the graph when some things load but it's not reflected in the motion on the screen which is strange, anyways, I'm getting ~60fps everywhere at 3440x1440, Ultra+ settings with all raytracing enabled. Hairworks is off, didn't make much difference to fps but I thought Hairworks off actually looks better?? Not seen any framerate drops anywhere either so reckon I am in the minority crowd that have no performance issues on this, at least on GOG anyway.
I have Reflex set to Ultra+Boost and that's made the mouse movement instant which actually makes a nice difference in how movement and camera respond.
DLSS is set to Balanced with sharpness set to high, resulting in:...
no I just downloaded the whole game again and all my mods and saves were still there so I just picked up where I left off in Toussaint. I have both expansions completed earlier this year but still loads of side quests to doI assumed that I would have to start a new playthrough for this new version?
Looks pretty good on your system, what GPU do you have again mrk?
All new games are either broken or just dogturds.
Cats are allergic to witchers.The cat in the tavern hissed at me, I think it has issues.
Now crashes for me as soon as I enable ray tracing. Wasn't doing this yesterday. Nothing changed my end.
Mine won't even load, just crashes on loading screen, twice now, what a stupid update, seems bugged as hell
