LG 42-inch OLED
Is it just me or does the TV want to turn off after x amount of hours (comes up with something along the lines of press an input or the tv is turning off . . . . ). I have turned the 4 hour auto turn off in the settings yet this does pop up randomly.
Anyone have a suggestion besides get outside more :-)
Anyone have a suggestion besides get outside more :)
... Press a button once every 4 hours? It's not distressing :D
It is distressing, it gets in the way of my killstreaks ya know! So I guess there is no way to turn this annoyance off. Damn you LG, DAMN YOU! *Shakes fists in the air* :cry:
Folks.. watching some movies on disneyplus, I notice juddering in some scenes. I guess this is probably to do with no trumotion being turned on?
I was told that you cant turn this on from a PC input? Is there anyway round this?
Use the disney app built in to the tv to watch disney?
Smartarse :D
(Actually yes I was thinking that but then I was also thinking about other video sources that I would plan natively on my PC, e.g. youtube and content on PC?).
Sorry I should have made my question clearer!
Smartarse :D
I think you just need to switch off the game optimizer. A pain.
Really? Simple as that?
Hmm doesnt seem to work bud. Doesnt the juddering bother you?
I think he means the TV itself than the remote? I have to pay press twice also I believe on the TV.
No I mean the remote. I press the power button once and then it goes to like a screen saver with language options and then I have to press it again for the TV to actually switch off
Oh right sorry for my assumption! Im sure there must be a setting in General settings somewhere. I only have to press it once on the remote as well.
I will be completely honest bud, I believe so. From the moment I started using it.
I THINK there is a feature called Always Ready.... is that on for you? if so turn it off and see what it does.
Ok so I've had another look and when I press the power button on the remote it goes to a music menu where I can download music, choose a Bluetooth device or play music from a flash drive....
Any ideas?
Any ideas?
Ok I've found it! It was a feature called "always ready". I've enabled the feature that still has it active but disabled the wallpaper.
Issue resolved
