Ah. Those were dang noisy tbh dude. The 3mms, like. Won't be using those again the burrs are silent in comparison.
Yeah I think you are bob on when it comes to the noise. It was totally taking the pee really. Lessons learned...
I think the bed is level with the cutter. I think it was as pointed out - discrepancies in the cast itself. I have now learned where my machine likes to be in order to go all the way through. You max the bit out on the piece, then back it off two presses with Easel. So no issues there now.
Problem with a fence and it being in the same place is that on this bed size it is never in the same place. I have to position the acrylic before I line up the bit with the piece because I often have to have the piece poking out of the bottom (because of the bed size).
BTW those crimps are wrong I think. I thought it included ATX female pins but they are tiny. Hoping they are large enough to crimp ATX pins. I need them any way, but will be annoying if I have to buy tons more gear.
