Whats the measurements of the cleaning station as Im going to have a go at 3d printing a shelf out? Hopefully I will be able to put it in-between the mirror and toothbrush.. The toothbrush stand is also 3d printed as you cant buy a braun toothbrush with a with a wall charging stand anymore.I'm using the Panasonic dock station all the time now, just much more convenient.
Well I was going to print it in white but then thought it will probably be better in black because the station is grey and black, and the only reason for doing the toothbrush stand in white was because the toothbrush is whiteThat looks nice, paint it white to match the surroundings though?![]()
Tbh really liking it so far, only frustration is sometimes when the neck hairs are too flat but the back blade sorts them outI finally found the measurement for the cleaning station(older version, but looks the same other than the colour) and I have only 2-3mm of wriggle room to spare on the shelf width ways.. And no problem back to front as I made it bigger to leave some room for the fan..So the shelf is the perfect size if the older station is the same size as the new 1, and will be using a bit of bluetac so it cant be accidentally knocked off...
@goldy6660 How are you liking the shaver?
Liking the 79 here too. Neck hairs are always a problem for most foiled shavers, the back trimmer though as you say sorted them out and just so happens the Panasonic back trimmer is really good compared to teh Braun series 9 one I am finding. I just wish that shavers came with a narrow popout trimmer too to tackle hairs that grow around the ear hols that are on the outside, but inside that little recess bit lol.Tbh really liking it so far, only frustration is sometimes when the neck hairs are too flat but the back blade sorts them out
@Roar87 @C Kent @Chris Wilson @arknor @Energize @dowie @[FnG]magnolia (mags purely for the fashion).Liking the 79 here too. Neck hairs are always a problem for most foiled shavers, the back trimmer though as you say sorted them out and just so happens the Panasonic back trimmer is really good compared to teh Braun series 9 one I am finding. I just wish that shavers came with a narrow popout trimmer too to tackle hairs that grow around the ear hols that are on the outside, but inside that little recess bit lol.
Anyways, I didn't shave for a week and today figured I'd see how capable the 79 really is (used dry), did a fine job and feels like a wet blade shave:
I think even the guy across the road approved as he gave me a straight arm salute which I didn't quite understand but some folks are a little different I guess and I just nodded and carried about my business.
You mean the 97 And it looks like it did a pretty good job too, how long did it take and did it take a lot of passes?Liking the 79 here too. Neck hairs are always a problem for most foiled shavers, the back trimmer though as you say sorted them out and just so happens the Panasonic back trimmer is really good compared to teh Braun series 9 one I am finding. I just wish that shavers came with a narrow popout trimmer too to tackle hairs that grow around the ear hols that are on the outside, but inside that little recess bit lol.
