I will take alook thank you!check your minimum processor speed in classic control panel\ power. I had this and nearly wiped my pc then noticed min cpu was set to 5%, set it to 50% and everything's fine again
Yea i have recently started using Firefox over chrome for this reason, chrome has like 15 instances open for 1 tab, its crazySome sites give a lot of lag with me with chrome but the same sites on firefox do not, ive had the same page in Chrome use up 80% of my CPU but on firefox under 5%, if you get slow downs again check CPU usage whilst you are on the tab for the game you are playing.
ive been thinknig abou going back to windows 10, I was on windows 11 before the upgrade tho and it worked fineI found my PC (same processor as you) is laggy and not that snappy any more, since I upgraded from Windows 10 Pro to Windows 11 Pro.
ive noticed now i get a crackling sound in my speaker followed by 1/2 secs of lag and then the computer starts to run sluggish.
ive been thinknig abou going back to windows 10, I was on windows 11 before the upgrade tho and it worked fineive noticed now i get a crackling sound in my speaker followed by 1/2 secs of lag and then the computer starts to run sluggish.
i run latenacymon and it shows a sound card driver or files as the issue but i can not for the life of me get rid of that error![]()
