It will be 6 years in May since my last build and it's time for a new system
My financial situation has changed recently so I am able to spend more on my new system than I was originally planning and have decided to go all in and get a high spec system that should last at least another 5 years and hopefully more than that. I appreciate that this build is probably over the top and there are places that money could be saved but I'm more interested in whether or not it will all work together
My basket at OcUK:
I've always gone Intel/nVidia and although I was considering AMD/AMD this time around it seems the 7900XTX isn't that much of a bargain - had the price been lower or the performance higher I may have gone for it but it seems that, at the moment, if you want best performance you need a 4090. Another habit is using same motherboard/GPU manufacturer even though I am sure there is no advantage in doing so. Current setup is Asus/Asus prior to that I was running Gigabyte/Gigabyte and the Gigabyte RTX4090 is available from Overcloskers with a small price reduction so I'm happy to go with it. Other bits are latest versions of things I have used before - Corsair, Noctua and WD usually feature in my builds somewhere! I've not used Fractal Design cases before but have seen good reviews of them. My PC sits on a shelf alongside my desk and RGB is of no interest at all so a windowless case is ideal for me. I have added some case fans but may reduce the number - I probably don't need 4 of them. I already have KB/Mouse/Speaker/Monitor/Headset so no need to add them in, if I do decide to change them I will do so later on. I also don't need 64Gb of memory but I retire in a couple of years and want to play around with virtual machines so I may as well get a decent chunk of RAM to start with.
My basket at OcUK:
- 1 x Kingston FURY Beast 64GB (2x32GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit (KF556C40BBK2-64) (SKU: MY-29W-KS) = £389.99
- 1 x Gigabyte GeForce RTX 4090 Gaming OC 24GB GDDR6X PCI-Express Graphics Card (SKU: GX-1FC-GI) = £1,829.99
- 1 x Intel Core i9-13900K (Raptor Lake) Socket LGA1700 Processor - Retail (SKU: CP-6AZ-IN) = £599.98
- 4 x Noctua NF-A15 PWM Chromax Premium Grade Fan - 140mm (SKU: FG-06M-NC) = £29.00
- 1 x Noctua NH-D15S Chromax Black CPU cooler - 140mm (SKU: HS-03R-NC) = £99.94
- 1 x Gigabyte Z790 Aero G (LGA 1700) DDR5 ATX Motherboard (SKU: MB-5BL-GI) = £399.95
- 1 x Noctua NT-H2 Thermal Paste (3.5g) (SKU: TH-001-NC) = £11.99
- 1 x CORSAIR HXi Series HX1500i Fully Modular Ultra-Low Noise ATX Power Supply (SKU: CA-26Y-CS) = £279.95
- 1 x WD Black SN850X 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive with Heatsink (WDS100T2XHE) (SKU: HD-593-WD) = £129.95
- 1 x WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive with Heatsink (WDS200T2XHE) (SKU: HD-594-WD) = £269.98
- 1 x Corsair PCIe 5.0 12VHPWR Type-4 PSU Power Cable (SKU: CA-272-CS) = £18.95
- 1 x Fractal Design Meshify 2 Midi Tower Case - Black Solid (SKU: CA-098-FD) = £184.99
Total: £4,347.54 (includes delivery: £15.90)
SAVE 17%
£579
(incl. VAT)
£480
(incl. VAT)
SAVE 5%
£110
(incl. VAT)
£105
(incl. VAT)
