- 1 May 2013
- M28
7900XT ? no, its not that type of design to hit 599 GBP. It (7900XT) was never designed to hit that type of price target, it was designed to take the chips that don't make the grade for the 7900XTX but the actual reference PCB card, bus and Vram specification puts in a tight spot bill-of-materials wise to cut retail price toe-to-toe with the 4070ti.
The problem is that the regular Joe's don't know what they are buying, they just see the Nvidia badge and DLSS 3.0 sprayed on a box.
The 4070ti design, allows it to be a cheap card.
Here is a near reference 4070ti PNY, it has 9+2 PCB phases (https://www.techpowerup.com/review/pny-geforce-rtx-4070-ti-oc/4.html). This is roughly in line with the PCB quality of the 2070 Super which, had a 256bit bus width and 8GB Vram.
The 4070ti has 12GB Vram with a 192bit bus that permanently cripples the card.
This is a reference 7900XT, look at the quality of the engineering in comparison to the PNY 4070ti, it has 14+3 phases with 70 amp rated components.
The 6800XT was 12+3, the 6900XT was 16+3, so its somewhere between the two in terms of PCB but the 7900XT has 20gb vram and 384-bit bus.
In terms of historical context, one of the best made cards I ever handled was an EVGA 1080 Classified, that card had 14+3 phases with a 256bit bus, it weighed a ton, had dual fans and cost 700 USD in 2016. That is about 750 GBP inc. Vat now. That is the level of engineering that the 7900XT reference PCB has.
Therefore, the 'real' price for the 7900XT reference is probably somewhere between 700-800 GBP inc Vat. The real price for the 4070ti reference should be in the 450-500 GBP range, maybe lower, they are just two different cards at an *engineering* level, regardless of what the graphs say. The 7900XT is just a class above the 4070ti.
Do you examine the PCB of all the products you are buying? I usually go off trusted reviews. Bet they have your face up as one to watch in Curry's
