Thanks for all the help guys, will have a think over.
Maybe not, but shows what's available on the used market.They might not be able to access it.
I have 32GB, I do not have an nvme, only an SSD. Does that make much of a difference?Now get a 5800x3d and youll be laughing. How much ram do you have? Nvme ssd?
No a SATA SSD is basically as fast for gaming as an M.2 SSD.I have 32GB, I do not have an nvme, only an SSD. Does that make much of a difference?
I have 2933, as I used to have a Ryzen 2600 and the max memory speed for that was 2933, so that is what I bought.What speed ram? Although tbh, doesnt really matter . As above nvne wont be noticeable , but the 5800x3d is a great cpu
Do those other places not count as the used market?Not if they can't access the MM it doesn't. If they can't go into the threads then how do they know what's in the used market unless they go somewhere else like FB market place, gumtree, ebay etc.
Do those other places not count as the used market?![]()
Right now everyones knickers are in a twist because instead of the new generation cards "replacing the old" with similar prices but a jump in performance, the GFx card companies have decided to simply stack the new range above the existing and align the price of the new cards accordingly. Whilst its not what happened previously, in general terms, right now the more you pay the faster card you get. If you are in the market right now for a Gfx card you have no choice but to plump for the card that gives the desired perfomance and pay the asking price. I think everyone agrees the new gen cards are great cards, just no one likes the new pricing strategy. For you, keeping cards for a good stint, the "extra" cost will amortise out over the time of ownership. All cards mentioned above will do what you want right now, but given that you keep cards a while, I think I would opt for something with more vram and higher mem bandwidth than the 4070ti as you may well upgrade that 1440p display before your card in the future. Don't forget to flog the 1080 on the MM for a little subsidy towards your new card.
