Need a new MTB - struggling to make a decision
Caporegime
8 Jan 2004
Rutland
I've had my current MTB for about 10 years. It has been decent but the time has come for something new. I mainly do road/forest tracks and would like to start doing some proper trails this year.
Budget is flexible, was thinking upto 1K. Was going to use the Cycle2work scheme if possible as it seems to be a decent saving.
I've got three main choices I'm mulling over at the moment:
Vitus Nucleus VRS - £500 - cheap air spring, Deore x10, looks a bargain but has a QR rear axle which might be a pain in future to upgrade maybe?
Bizango Pro - £950 (but can get 10% off with BLC) - better spring, Deore x12, better fork, better brakes, thru-axle on the rear
Vitus Sentier VR - £1000 - better fork than the Bizango Pro, dropper post (not tried one of these before), Deore x11 - pretty similar to the Bizango overall apart from the better fork?
Given that I only buy a bike every decade or so my though is to just get a decent bike but I have little ability so the Nucleus may be more than enough. Anyone got any ideas or alternatives?
Watching this thread as have similar requirement :)
Bizango Pro looks awesome value and is well reviewed everywhere. Sentier also looks good but its black and I don't like black bikes!
I'm waiting to see if the Bizango Pro goes on 10% off like it did before Xmas. That was a steal, should have just paid outright and not tried the cycle2work scheme.
The Vitus have much better components then the Voodoo. The voodoo has generic Shimano drivetrain where as the Vitus has full Shimano Deore. And I think the Vitus has better forks.
I would go for the Vitus anyday over the Voodoo.
I'd go with the Vitus purely for the better forks, not sure how much you'd notice mind. The Deore 12 speed (vodoo) is better than the 11 speed though.
I though the Bizango Pro has Shimano Deore too or am I missing something? The spec says the derailleur and chainset are Deore.
I started out with a Boardman Pro 29'er Hardtail from Halfords 4 years ago. Did all sorts of outings on it, Peak District, Lake District and took it all in it's stride. Can also have a look at:
Or you could try a full sus in the same budget.
Be careful, it get's addictive, i went from having no bike to having 3 in the space of 3 years.... Just don't tell the wife how much they actually cost.... :D
I have a 2021 Sentier VR, is a great bike however I'm now looking at replacing it with something full suspension.
The cycle to work scheme is fairly painless, it's fully paid up now but technically I don't own the bike for another 3 and a half years or something (as that is the cheapest ownership option after it's paid off)
After endless debating order the Bizango Pro, just picked it up and the fork is damaged:
I know it's probably cosmetic but the fork has been pretty battered.
You never really know how far damage goes really so best to get them to sort it, sucks regardless!
That was my thinking. Ball ache!
I had a bike delivered from CRC for my daughter this week. Beautifully packaged and loads of extras. Halfords have a way to go!
My sister/BIL tried to buy a couple of ebikes through Halfords and after about a month of achy balls they ended up cancelling it all (which was problematic of itself) and then got bikes from elsewhere. Halfords is always going to be Halfords unfortunately
If you end up binning it off and looking for another bike I could be convinced to sell my Vitus now I have a new bike incoming ;)
That is a shame. Can you not go to a store and collect? Their bike building is shoddy, but at least you can inspect it.
That was collected at a store. Didn't notice the damage until I put it in the car. The salesperson mentioned the damaged box and said it should be well protected inside - there wasn't anything at all on the fork.
They've ordered me another one, I'll just build it myself. Should get it Monday.
