- 7 Sep 2020
- Gods Country
same here....Think mine is going to suck today unless it brightens up considerably!
would be laughing (or impaled) if i had a wind turbine, but no sun today![]()
Great work! How did you do this? (Ie setup, I'm pondering the same)1KWh off my shed roof yesterday, 6 340w panels (3E + 3W) was getting 12/13KWh in the summer. Cost £1,500 all in to install (diy).
4kwh+ today, had a brief sunny spot at lunch
It was kinda like that actually, absolutely pouring all day, then suddenly clouds cleared and inverter was up to 4kw on app, then by 2pm it was pouring down again!This is how I imagine Katie gets sunshine when she needs it.
Mounted 3 panels each side of my log cabin (shed) https://imgur.com/yL29hOqGreat work! How did you do this? (Ie setup, I'm pondering the same)
Yes - filled out a form (G98 Form B) sent to Western Power Distribution and received the ok.Did you inform the grid of that?
DIY - I'm fairly competent.Nice.
Did you connect into CU yourself or get a sparky to do it, I think technically that's notifiable isn't it? (adding a circuit, especially one thats outside)
Not that its not easy to uninstall yourself as well of course, just wondering![]()
already exceeded yesterday, and its very cloudy hereAlready started exporting for today, could be a good day
