Well guys I think my previous temperature concerns may have been a little inflated. The problem was that for some reason "Enable low level driver" was not enabled in MSI Afterburner, so temp readings were 5-10c higher than they should have been and when I enabled the low level driver it corrected that and it now idles at around 49c with the fan profile I have set.
Below you can see what my temps now look like at stock OC speeds after a run of TWW3 battle benchmark (it is a torture test and maxes out a GPU hard at 4k Ultra). Max stats it reached during the benchmark are on the left and you can see which stat is being recorded on the right.
Does this look more reasonable now considering it boosts all the way to 2775mhz?
