Don
- 20 Oct 2002
- Oxfordshire / Bucks
Anyone know a good place to get touch-less atm?
https://bilthamber.com/product/touch-less/ ?
https://www.cleanyourcar.co.uk/bilt-hamber-touch-less ?
Just the two places I've personally ordered from above, there will be more places to buy from.
Don’t think I’ve ever seen the car so dirty after just a week, the roads are grim. Probably not much point in doing more than a quick foam, pressure wash and leave. Next week won’t be any better. At least the frozen floods have mostly cleared.
Edit: looking at the forecast and how cold it still is I don’t think there’s much point. Will do it next weekend when it looks much milder.
Edit 2: decided to go for it, just needed to thaw out the pressure washer in the sun. I do love autofoam, a good soak, 50:50 dilution, very little pp on there, a car covered in salt and mud, no contact wash:
you dont need to use that much BH
try 40/60
When it runs out, get the touchless
Mine got so bad yesterday had to stop to clean the number plates the salt was so thick you could not see them anymore = £1K fine now if stopped & reported!The roads are shocking. Washed last night, car was gleaming, then 10 miles local driving and it looks just as bad as before the wash.
Certainly notice how the roads that don't get salted actually dried up today so would have been fine, but the rest were so greasy and wet.
Definitely going to buy some of that Car Pro Tyre cleaner...looks like it works well on the pics.
