- 4 Aug 2007
- Wilds of suffolk
see post #2Is it not calculated based on your consumption for that current period across an average of dates?
see post #2
It's amazing you can move 40kwh around to basically break the system.
I mean, if the route cause is for people to shift usage I suppose technically you're doing it very efficiently.
Wonder if this is "OK" by them. Or they will change the calcs
I would assume that 1. A tiny % of the overall population is even taking part in in the SS. Within that tiny % a microsopic % are able to adjust their normal usage in a way to take advantage of the situation. Thus nothing will change (because of the gaming, they may change things due to other factors though)
I mean it sounds like you're genuinely using that 40kwh. Not like you've bought something that would waste the energy. Which is the objective of the scheme... Ish!
So really, doesn't even seem "wrong".
Not that anyone would care!
So just to be clear, that's all typical stuff, plus house and car battery?
Yep. Everybody (that's sensible) here is moving genuine usage away from the saving session window, as instructed. There's a financial reward for doing so and that's great. If it helps the NG i'm all for it.
Gaming it should disqualify you from the sessions really. It's totally not the point.
i know you dont like me and im ok with that..its the internet after all.Yep. Everybody (that's sensible) here is moving genuine usage away from the saving session window, as instructed. There's a financial reward for doing so and that's great. If it helps the NG i'm all for it.
if moving energy from other parts of the day, into a 3 hr window before the session....then yes its gaming. Because i dont know anyone that could use 48kwhs in a window of 4pm to 5pm.Is it though? If the aim of the thing is to "increase/decrease consumption nationally during specified times" and people are using 0 during that time is it really gaming the system? Or achieving the objective?
but some have already reduced their demand at those times, because they have batteries, solar and dont use grid power at those times in the first place.Yeah but isn't the actual objective to reduce demand at x-y o'clock?
So even if someone is using all thier power before that time, if they are using 0 during it, it is helping the grid?
