Can you not do this in Bitwarden?
Do you have the Bitwarden browser extension installed? It definitely works here without me changing any keyboard shortcuts and was something mentioned to me when I first installed Bitwarden.This just copies my clipboard into edge.
arstechnica.com
Cheers for the reminder, forgot the Firefox extension finally updated a few days back, can safely switch to argon2id.Due to having a very early Bitwarden account had to manually upgrade my security key encryption now the options are there, switched to argon2id from KDF
I created my own, I don’t trust big companies as they are big targets, keeping that many eggs in one basket is bad. Mine is just an encrypted grid with a master password and buttons for each item. clicking the button copies a decrypted value to the clipboard so I can paste it. Its not perfect but its free and works better than trying to remember 50+ passwords.
Reading around I seem to see the same few recommendations but no clear winner - any views on here? Bit warden, Dashlane, Keeper and 1pass seem to be leading the pack.
I went to 1Password after the lastpass debacle, seems far better integrated and auto fills virtually everything across mobile/PC without intervention. Lastpass had some repeat niggly issues with that.1Password here.
This. Keepassxc is my solution of choice. I'd rather not trust my passwords to anyone but me.For me it would only be either KeePassXC or Bitwarden (Vaultwarden) as both can be run locally. While I'm sure some of the others are equally as good I just won't put my trust in something that's out on the internet managed by a third party, especially when it comes to login credentials that basically run peoples lives these days.
That's fine, but most of us know nothing about InfoSec etc, so I trust someone else knows more than me.I'd rather not trust my passwords to anyone but me.
