I've received this email from Shell, again.
Is this just a forceful tactic to get eveyone onto smart meters? I contacted our management company because everyones meters are maintained by the property manager with no access to residents.
Smart meters cannot be fitted as have caused issues in the past
I contacted Shell maybe 6 months ago and they said to ignore the email
We’re getting in touch to let you know that your Radio Teleswitch Service (RTS) meter will lose functionality from March 2024.
This is due to an industry wide change that will affect the radio signal your meter uses to communicate.
This change means your meter won’t be able to support your multi-rate tariff, as it’ll be unable to switch to your tariff’s cheaper off peak rates. In some cases, this change may also cause a permanent interruption of your home’s central heating, as well as your meter’s ability to record your energy usage accurately.
It’s important that you take steps to arrange a replacement for your RTS meter, and we have just the thing.
Choose smarter home energy
Our SMETS2 smart meters allow you to keep your multi-rate tariff without the fuss. A smart meter provides detailed breakdowns of your daily energy use, so you needn’t wait for your bill to arrive to understand your energy use.
On top of that smart meters submit your readings for you, always produce accurate bills, and help you to keep track of your energy usage.
