Man of Honour
- 5 Jun 2003
- Falling...
Typical!
12.01kWh today which means an efficiency of 3, almost a perfect day as well, just a little dip around 1pm. 18 October was the last time I got that much in a day.
That's because my electricians coming that week, and the panels are going on the roof.
You can use something a bit like this for the Givenergy local pvoutout:
GitHub - cdpuk/givenergy-local: Home Assistant integration for local access to GivEnergy inverter and battery systems
Home Assistant integration for local access to GivEnergy inverter and battery systems - cdpuk/givenergy-localgithub.com
It's just a bash/shell script that sends the sensor data to a web url with an API key and a System ID that you get from the pvoutput website.
You may need to change the sensor names based on what Solis calls the equivalent things.
Once the service exists you can call it on an automation schedule to run.
Think I've got that all set up now... we'll see if it starts sending data tomorrow (I added a sun above horizon condition).
Ummmmm…….No, i was the most efficient of all yesterday. My small system working wondersWere you more efficient than our welsh man @Ron-ski ?
your gif is broken....but i think i got the jist of it lol
You'll probably want an offset for the Sunset to make sure nothing is missed.
I use hourly, but I have an offset on Sunset.
Otherwise it will miss data after sunset, with hourly if it finishes generation at say half past, but sun goes down at quarter to, then it would not submit anything for the prior hour.
i need to join the OCUK team zeefly......Well the good news is it’s all up and running, data is showing up in PVoutput.
I’ll have a look at tweaking the conditions like you have. Seems to have started capturing at 9w output this morning.
I’ll have a look at tweaking the conditions like you have. Seems to have started capturing at 9w output this morning, I have 5 min intervals which is probably excessive lol
What size system have you got, I can't remember?Ummmmm…….No, i was the most efficient of all yesterday. My small system working wonders
You have, I can see you on there.@Welshman I believe I have?
3.24kwh systemWhat size system have you got, I can't remember?
Cloudy down here today.
i can see you there now@Welshman I believe I have?
I don’t seem to be correctly exporting yield, need to take a look at the variable.
Impressive, strong rays on that Welsh mountain.3.24kwh system
