Don
- 20 Oct 2002
- Oxfordshire / Bucks
You can apparently buy replacement custom faceplates. It does look however that the lenses have a fixed IPD.Just watched a video with the CEO. The headset itself is configured to your IPD. That's gonna hit the resale value.
Yeah, but it's clear that the lenses can be moved. I suspect when you order they fix it in the correct place, if you resell, I imagine you can whip out a screwdriver and slide them along or similar.according to my link above
when you order it , you have to use an iphone , and use an app, it takes your IPD and something else, and when you order it, its custom made to each individual
and you can get prescription lenes that attach on , for glasses wearers
Doesn't sound like it from the videos I've watched, check the Tested one posted earlier.Yeah, but it's clear that the lenses can be moved. I suspect when you order they fix it in the correct place, if you resell, I imagine you can whip out a screwdriver and slide them along or similar.
I think you give them your eye prescription during ordering, so sharing and resale is dependent on being able to order a new lens & face cover.Also no room for glasses. Does it have a diopter adjust?
The other issue is no eye tracking so no dynamic foveated rendering....
As a 4090 owner I can tell you with absolute certainty there are many VR scenarios where a 4090 struggles with the high resolution of the VP2 you need foveated rendering for hires displays its scandalous to claim a 5700XT is the requirement. Yes it may function and yes there are a ton of poorly optimised VR games but that is the world we live in right now.
One of the reasons I like the Quest Pro is it's no more stressful on the GPU than a Quest 2 but looks massively sharper. Like several orders of magnitude sharper. It's like getting a GPU upgrade for free.
So raw resolution isn't necessarily the only factor in how clear and sharp a headset is.
If the Beyond is using pentile subpixels then it's immediately losing effective resolution too.
Impressive form factor that's for sure. For those who have the Steam Controllers and base stations a possible upgrade from the Index etc, though that FOV is a bit of a step down. For me I'm still very impressed by the PICO 4 for the price, though it needs a might GPU to offset the overhead of wireless streaming. I've got a pre order in for the Pimax Crystal which price wise will be roughly the same as this plus the required base stations and controllers. Though I'm a little sceptical of what they are going to end up delivering.
Good to see more and more progress in the VR arena. I wonder what other headsets are close to launch?
That is very true, but its also a problem that isn't going away anytime soon. As you jack up the hardware resolution even the RTX 4090 struggles to serve 90fps to two hires VR displays...Most Sims are actually not that well optimized for VR which is why you get problems running at max detail and high frame rates.
