PC Gaming Headset
19 Oct 2010
Hi. I play simracing so i'm after, i think, a surround headset. I'm happy with wireless as long as I can use it whilst it's being charged over USB? I'd like a mic.
The Razer stuff looks good but i'm unsure on the different versions.
Thank you.
Depending on your budget and if you have not already got yourself a headset, here are a few suggestions: Midrange Price £60-£100 - Roccat Elo Air (Wireless) or Elo (USB), Corsair Void Elite (Wireless or USB). Higher End £100+ Roccat Syn Pro Air (Wireless), Corsair HS80 (Wireless or Wired) Any of the EPOS (Sennheiser Gaming Brand).
I've had a pair of £20 headset 6 years ago. Wasn't to bad. The difference between a £10 headset and a £20 headset is very noticeable. Going from £20 to £50 is about as noticeable again then £50 to £100. From £100 onwards your getting into audiophile area when you wont notice that big of a difference between £100 and £200.
Thank you.
For some reason the Arctis Wireless Nova Pro for Xbox is about £35 cheaper than the Arctis Nova Pro Wireless. They appear identical. Will the XBOX one wortk on PC?
Thank you.
They both work on the PC. The Xbox is the one got purchased a few weeks back but I only use it on my PC.
