Those screenshots can't be real, who willingly plays with chromatic abomination set to ON??
the Commissario ask us to get back on track!
Hogwarts Legacy GPU Benchmark: 53 GPUs Tested
Hogwarts Legacy is open-world action RPG set in the Harry Potter universe. Having launched to very enthusiastic user reviews, it's time we benchmark it and we have...www.techspot.com
Did you try out the other upscalers? AFAIK NIS should be the worst of the lot.I enjoy 4K at 60hz and my graphic is set at high\Ultra on GTX1080 TI, I don't see why a game should run above 120hz it isn't a FPS game
It's inevitable. Just cave.I really should get this
I think if you lower the difficulty level to easy then you will likely get rid of this. I haven't tried but it would make sense based on what happens with the hard mode.I'm colourblind & had terrible problems with Crossed Wands : 3
The only colour I can reliably tell apart is the Blue. The other 3 look almost the same to me.
It's made worse by the fact they de-saturate the colours as you lose health.
I tried both the red-green colourblind modes & neither helped.
In the end, I had to learn the enemies names & what spell to use & take them out 1 at a time.
Are there any other visual cues apart from the colour of the bubble as to what spell to use ? (I don't have a problem on the spell selection, only on targeting the right enemy).
For those much further in - how important is this going to be ? Is it very common to have a lot of enemies on the field at once, all with different colour bubbles ?
Wait till they patch performance or get it on console.I really should get this
My pal only realised that you get most of your XP from the pages 26 hours into the game so he was going through it massively under-levelledIs the pacing of the main quests weird?
I'm level 26, 20 hours approx of game time and have pretty much seen all of the world and unlocked all fast travel points. Done loads of Merlin quests and balloon popping etc but...
I've only just got the unlocking spell and animal collection spells.
It's almost like they built the main game, realised that it needed padding and added extra stuff.
Even the way quest givers talk to you it's like it's your first day at school.
Still loving it though!
Mine was just under 20GB system memory and around 9GB video in a quick test as reported by gpu-z
How's the memory usage for others? It more or less maxes out my 16GB to start with 90-95%(around 9-10GB) usage then drops of to 55-60% after a while. (3-4GB) Which seems odd considering the very high memory usage reported by others.
Video memory is pegged at around 8GB so even the 10GB 3080FE cards should be ok.
Around 20GB system memory and VRAM hovers around 7.2GBHow's the memory usage for others? It more or less maxes out my 16GB to start with 90-95%(around 9-10GB) usage then drops of to 55-60% after a while. (3-4GB) Which seems odd considering the very high memory usage reported by others.
