The reference point for the dissapointment is not Nvidia. It's AMD.
They had enough product launches where the products released met, and often exceeded, the promises AMD made before hand.
Then, with RDNA3, they basically said "Haha! You suckers should have read the fine print!"
Did RDNA 3 even meet the 50% performance-per-watt increase? I suspect they have some scenario, somewhere, their lawyers can point to, (in the fine print) but I don't recall seeing it anywhere.
Are we at the point where we are now so used to Nvidia BS that we are accepting of it and instead direct our frustration at AMD?
