Don
- 20 Oct 2002
- Oxfordshire / Bucks
mint !
so just purchased some of the bilt hamber touchless and was working out my PIR and with a litre in the foam gun I got roughly 11 litre in the bucket after the test meaning a PIR of 4% i need to use 440ml of touchless. does that sound high its certaily more than i would use on other Pre washes. obviouslyt what i dont use i will save into a spray bottle to use later doubt i will use the entire litre on my car.
Was gonna say the same. I only use 400ml total from the bottle.I got about the same recently and realised I only need to use half of the bottle on the lance.
BH Surfex HD, i know these are supposed to be amazing APCs
but is it suitable for cleaning wax/polish off from trim, interior and exterior plastics ?
if it is, then saves me buying two things
i need some more APC anyway, mines nearly out (cheap crap)
I’ve found it’s generally good for residue of all kinds if you leave it to soak for a bit.
I use a foaming sprayer so it clings to the surface I’m spraying onto a bit better.
Did a great job on leather at 10%
Speaking of leather, what do you guys to clean your steering wheel, and get it back to a nice matt finish?
Edit - see below.Speaking of leather, what do you guys to clean your steering wheel, and get it back to a nice matt finish?
APC should never be used on leather.
