Poll: Ryzen 7950X3D, 7900X3D, 7800X3D
Will you be purchasing the 7800X3D on the 6th?
  • Total voters
    191
  • Poll closed .
I watched the Gamers Nexus review on it and he basically said when companies only send out one sample its abit sus. Either the 7800x3d is too good and will take away sales from the higher tier chips or its absolutely pants and abit of an embarrassment :cry:. Have to wait and see
Is it really worth another £150 ?
No i don't think it is but when you're spending over £700 on a CPU you're doing that because you want the best, the 3090 was never worth 2X as much as the 3080 but Nvidia sold it in massive numbers, because it was the best.
No, he meant 7900x3d, not 7800x3d ;)
We all know that 7800x3d will embarrass every CPU on the market
The 5800x3d is looking a very good buy right now. From trying to find places that have the 7950x3d i've seen it down to £330 inc
Seen it as cheap as under £300. Was really tempted, but figured I'd rather just do a full upgrade.
May end up going that route anyway if I see it particularly cheap since this stock situation was a total bust and I'm not hopeful that the 7800 is going to be any better.
HUB did the 7800X3D simulated by turning off the CCD with no cache, its a little better....
There are a lot of 4090 owners out there who want to get the most out of it and don't mind spending the money.
I'm really curious as to why AMD went the route of parking the 2nd CCD instead of doing what people have been doing for a while with multi-CCD chips and pinning the game process to one CCD using a similar method to process lasso. I'd like to think AMD have some special insight but given how their software dev seems to usually happen it's more likely it was just easier this way for them xD
What do you have to say the cached chiplet on the 7950X3D isn't the same as the cached chiplet on the 7800X3D
Freq max is 5.25ghz on the v cache CCD on the 7950X - multiple outlets have reported this. Whilst the 7800X3D according to AMD's own page has a max of 5.0ghz.
There is no way a chip of the same architecture with the same amount of V cache but lower clocks is going to out perform a chip of the same but with higher clocks.
Yeah but if the 7600x say isnt good enough for you in games +9% for +£500 isnt going to make a difference. Its not like say 110 fps is unplayable and 120 fps will make the extra £500 worth it.
The 4090 is different. Yes its expensive but it gives you massive gains in return. This dosnt, in strictly gaming only terms.
The difference isn't 9%. That's what I'm saying. And in the worst spots the 7600X chokes hard and you go even below 60 fps. THAT'S the issue, and why you can't just look at reviews and take them at face value. You need experience with the game & scenes. (See @Dave2150 's results in the post linked below the article link)
This is weird as hell. Cyberpunk is a GPU centric title. And there's next to no difference between any of the AM5 cpus in gaming loads, the 7600x is within a few fps of the 7950x in any title. And unless these new 3D chips are going to take GPU workload onto their cores, it's not going to matter.
What did you do, pick an arbitrary title and fps level to hold against it? Paying 500 bucks for 5 frames is so dumb it almost transitions into immoral wastefulness
Cyberpunk in particular isn't a GPU centric title, it's an everything centric title, because it can use more of whatever you have to feed it and spit out more fps, better image quality, faster loading, more & better AI (esp. with mods) etc.
The 7600X isn't within a few fps of the 7950X3D, in fact in games that most demand more CPU power it's very far from it (see above, but there's plenty of other examples like Forspoken, Hogwarts, Factorio, Borderlands 3, Far Cry 6, Age of Empires 4 etc. the list is huge).
Btw I don't understand this focus on the cost of the 7950X3D, if you only care about the gaming performance then obviously wait for the 7800X3D. You get a 16 core beast because you need/want that many cores, not because it's the best bang for your buck.
Hallelujah. Reviews aren't entirely representative of actual gameplay.
