He must be loaded.He's the king of binning after getting a poor version of the 7950X (standard one) - Looking for a golden sample i'm presuming![]()
He must be loaded.
You are generallly on a variable tarrif which are basically locked to 34p max because of the £2500 scheme and how that works or you are on a cheaper fixed already. There are a very few and minor ones out there but literally there is a limit per unit being charged in the UK as domesitc. Yes it may be a penny or two different. We are not talking anything where my calcs have shown you are at possibly £77 at home on domestic use or even £150 a year for an office on business at 88p a unit.Not sure if serious.
Can you get your money back if you have opened them?Why do you need to be loaded to buy three processors and return two of them??
He’s doing it because it’s efficient believe it or not.You already have a good processor do you game at 4k you won't notice any difference.
Not sure how you get that.You talking business rates I assume. Probably should lead with that. Everyone is talking about domestic use and you have not defined anything. Yes always outliers but you need to give context. Silly discussion otherwise.
But if you are then a standard working day of say 100w x 7.5hrs x 251 days, less holiday (say 21 days) gives 230 working days = £151.80 a year. That is still a super high power draw difference and the extreme end of anything shown in reviews.
I have a VR rig in another room, which needs it's own CPUYou already have a good processor do you game at 4k you won't notice any difference.
We was talking business rate at £0.88. However for wahtever reason jigger is paying apparently more than the £0.34 domestic rate in UK when nobody should be paying more than that per unit (in 95% of any tarrif) and the others are within a few pence still. Maybe he on a really obscure tariff.Not sure how you get that.
Electric is 34pence per KWh.
100W for 7.5 hours a day, for 251 days is
(100 / 1000) * 7.5 * 251 * 0.34 = £64
Why do have different magnitudes for each core ?
I just watched the PC World video and this does sound like an issue. If you are gaming essentially you have an 8 core CPU and everything else goes onto that CCX as well. There should have been more awareness about this amongst the media. I will probably return my new build based on this. Maybe wait and see if there is a more elegant solution further down the line. Apparently it does work if you game and use another program in the background that will utilise all of the cores. It wakes them up effectively.He’s back.
7950x3D Is A Scam.
NOT 16 CORES► https://framechasers.org/ - Discord and Support► https://framechasers.or...m.youtube.com
LMAOI just watched the PC World video and this does sound like an issue. If you are gaming essentially you have an 8 core CPU and everything else goes onto that CCX as well. There should have been more awareness about this amongst the media. I will probably return my new build based on this. Maybe wait and see if there is a more elegant solution further down the line. Apparently it does work if you game and use another program in the background that will utilise all of the cores. It wakes them up effectively.
But it parks the other CCX right? I am pretty sure he said he tested it and unless he ran a program that utilised all the cores when gaming to wake the other chip up, it stayed parked and everything ran on the cached chip. Are you saying if you game and stream at the same time the other non cached CCX is active to help with the tasks? If so it's fine.This guy is such an idiot, its prioritising the CCD with the cache when gaming for the best performance, its not a "problem" its by design, its does not have a "dummy CCD on it" its a full dual CCD 16 core CPU.
