Works the other was as well presumably - if you're running a frequency optimised task, the stacked CCD will be parked and the background tasks will run on the frequency optimised CCD.- Unless your other applications and tasks exceed the core capacity of the stacked CCD, it’ll be forced all onto the stacked CCD.
They are background tasks - why does it matter which they run on?Which as Gordon explains, you’re running tasks on the lower frequency CCD if it doesn’t wake up the other cores. It would be better if the scheduling moved tasks about to maximise performance.
But core frequency can be different on each core as needed so the game cores can run at 5.25Ghz or whatever and if the task on the other 2 cores on the same CCD are doing background tasks they can just run at 2Ghz or whatever. No background task such as YT, Discord, OBS etc generally don't use the higher frequency needed. What are you doing as a background task or program running that will want to be running faster than the game you are currently playing as your primary thing you are doing?
I still don't see the problem tbh. It makes sense that it is all on one CCD till it needs not to be so having the other core sleep from a power and heat element actually makes sense to bunch it all up. I would hate to have it game using 4 cores on one CCD and then YT and Discord on another when it would add power, heat etc instead. Seems like you are finding something to sulk about honestly.You’re confusing the subject, it’s meaningless what activities somebody chooses to do or whether they’ll be impacted slightly, impacted significantly, not impacted etc.
They’ve implemented a noddy linear software solution to scheduling, at the same time relying on Microsoft Gamebar to do so (Again, hilarious). Not only is this, well, just plain stupid and hacky. It’s inferior to hardware scheduling or Intels Thread Director which is far more intelligent (although also far from perfect).
Then we throw on top their willingness to delay the 7800x3d part, which there is no logical reason to do so beyond rinsing early adopters when they may not know any better…. It’s a disappointing state of affairs, overall indefensible and AMD should be rightly criticised for it. If not people are wilfully ignoring it out of bias.
Presumably you can do a better job; Arguably if someone's got time on their hands then they could play about with Process Lasso and fully explore the scheduling behaviour.They’ve implemented a noddy linear software solution to scheduling, at the same time relying on Microsoft Gamebar to do so (Again, hilarious). Not only is this, well, just plain stupid and hacky. It’s inferior to hardware scheduling or Intels Thread Director which is far more intelligent (although also far from perfect).
How did we even get to this stage...?
A warning about click-bait trash video's, assume its BS and do your own research, i include myself in that.
I think its all about add revenue and “brand” building for many
WrongAlso, Intel's Hybrid CPU's work in the same way. it doesn't use the E-Cores when you're playing games.
I think that AMD are also responsible for the bad weather we are having todayYou’re confusing the subject, it’s meaningless what activities somebody chooses to do or whether they’ll be impacted slightly, impacted significantly, not impacted etc.
There's already been mention that further scheduling tweaks are coming, but it still isn't as easy as say looking at the performance counters and seeing how many cache misses you get running on a specific core type, as you don't actually know what the performance would be like, and whether it would be beneficial to move to the other core type.
To a point, if you have no games that will use more than 6 cores it will likely be just as good as the others. The problem is for myself at least it will not be as good as say the 7800x3D as I have games that will saturate all cores such as Stellaris or Star Citizen.In relation to the above debate on assigning cores in games can we also refrain from saying the 7900x3d is terrible based on intuition before there's any reviews/tests at all
its a high load in places across all 16 threads but its not over stressed.My 7950X3D arrived despite the DPD driver doing his best to make as little effort as possible to knock on my door. Managed to chase him down the drive and got him to deliver the cpu after about a dozen sighs that I wasn’t in when he knocked.
That wouldn't fix the problem. You don't want your games running in 2 different ccds, so what's the point of adding cache to both of them?It stunk when they didn't give both CCD's the cache, this is just lulz
