System Shuts Off randomly
9 Jul 2005
High Wycombe
Been struggling and trying to diagnose for a while, any help would be appreciated as long since lost my knowledge (since having kids and no time!).
Running a (I know its old but its what I have):
ASUS P8z68-VPro
Intel Core i7-2600K - no longer overclocked
8GB RAM
Radeon R9 200 series (on 3 monitors as individual screens, and the on-board doing a 4th screen)
1TB SDD
250GB Backup HDD
Windows 10 X64
A while back it was just shutting off randomly, did all the usuall, full re-install of windows, updated all drivers etc. Replaced RAM as thought this could be the issue, no change. Eventually thought it was my main and spare HDD so replaced with a SDD and a new small spare HDD, which seemed to improve it. I was only ever using it for web browsing, emails, watching movies etc.
Now, my boy wants to play games on his XBOX when he is with his Mum, and I wanted to be able to join him, but when I try, it works for a bit then dies, no warning, just shuts off - so seems its when its under load from the game (only playing on 1 screen). Leads me to think its the 600W PSU but unsure how to test (read the sticky and will probably just have to get another as it was beyond me).
The route quesiton is, is the spec I have likely to strain a 600W PSU (which is quite old) and if so, what should I replace it with?
Many thanks
ASUS P8z68-VPro
8GB RAM
1TB SDD
250GB Backup HDD
Windows 10 X64
Many thanks
600W PSU you state but what brand and model and age of the PSU?
If some cheap brand psu then all bets are off and I would say replace the psu as the fault you describe with it just totally shutting down and losing power leads to the psu.
Its an OCZ 600W if thats any help, probably over 10 years old
I just tried playing with only 1 monitor connected, and same thing. When I had more Hdds in the case it was doing it with normal use, so I am thinking the more power it draws, then it trips out. Any recommendations for a PSU, cant spend too much, so £75 max, unless there is a really good deal out there?
Which is better, Corsair, Seasonic or Kolink from Overclockers?
This is the one I would get on your budget :-
many thanks, just before I order, can I ask why that one over the others?
Quality power supply for the money and 750w of 80+ Gold. Anything else is more expensive and not within budget and not really needed for your setup. Also Kolink are junk PSU's.. so one to avoid even if prices look "good".
Many of the lower-end Seasonics are not actually built by Seasonic. I think the Core GC is their cheapest line (not the GC G12), but OCUK don't have any of these at the moment. Not sure about Corsair's budget PSUs. The Kolink Continuum are alright (as far as I know, except for the short warranty for the price), but they're out of your budget anyway. I'd say the next step up from midrange PSUs (in build quality and warranty) would be something like Toughpower GF1 or EVGA G6.
Have you checked system temperatures when gaming?
This.
I would also put a fresh sploge of thermal paste on the cpu. Also try stressing out your cpu and gpu separately. Oh and disconnect power connecters from disc drives and non system hdd's etc and test.
yes, temperatures seem fine for the CPU and GPU, nothing spikes really high, I am not really stressing the system like I used to when I used to game. I tried disconnecting everything but the essential and still seemed the same, apart from when I disconnected additional HDDs
Just been trying again, CPU got to 86C on core 4, 82-85 on others, GPU 82C
Think they got upto 88C on CPU and 87 on GPU before shutoff again?
Did a CPU stress test and it got to 88C, a GPU stress test and went to 94C - seperately they ran fine and stabilised. Not tried to run them together. Bed now, will look again in the morning. Thanks all.
Sounds like poor case airflow in addition to needing new cpu paste in addition to the new psu.
It'll be one thing after the other with a system that old, so draw a line somewhere and start saving for a new build. At least the psu can go in a new build so that wasn't a waste.
Took the computer outside and blew it out, fair bit of dust and temps are a bit better. Will give it another go later and see if its helped with the gaming, saves about 4-5 degs in the stress testing.
Tested this evening - 1 random shutdown whilst playing....done everything I can, now will wait on the PSU.
ignore, looks like its shipped, although only shipped today which is a shame as I was expecting it today?
so, new PSU in, no difference. Tried Prime95, seems to crash earlier now but temps are good. Have tested the RAM, thats ok, now trying it with the onboard graphics (which I use for a 4th screen) disabled as in the last crash it went all wierd so though that may be an indication and it now seems to last longer (upto 10 mins now and still going). Running out of ideas (and money), hope this works!!!
Why you assuming it’s hardware?
@freddie64 - will give it a go
@GaryTheSnail - I did a gresh install of everything, updated it all etc etc when I put in new SDD, and several other times. If its a software problem I wouldnt know how to narrow it down other than running the absolute minimum, which I have tried. It may be as simple as my hardware is really old and drivers are lacking, unsure how to find out
Ps - thanks for the ideas
