Speed of charging is a main factor, 7kW would fully charge overnight, 50kWh battery on the car I'm looking at, whereas a 3 pin plug would take 3 times longer at 2.3kW. Also, is it safe to leave a car charging overnight just off a 3 pin plug?
You can do it and it will probably be fine but there is a higher risk you’ll melt something. I’ve seen a lot more melted sockets from granny chargers than I have wall boxes but it that way.
It only takes one weak link to cause a problem and the weak link is usually the plug socket. New sockets are fine and reduce that risk but they wear out over time and they will probably melt eventually.
The other thing to think about is time of use tariffs, it’s much harder to take advantage of short periods overnight which are the cheap rate if you can’t get the power into the car in that window.
