Cant get a program to run on startup
14 Jul 2005
Birmingham
Hi have put a shortcut to PBOtuner.exe in the startup folder. It has arguments to set a core undervolt on my CPU.
If I manually click on the shortcut, it works perfectly. But it won't start with Windows.
I have it enabled in the startup control panel.
I have it set to run administrator privileges, it made no difference:
Anyone know why it won't load on startup?
I saw a Youtube video saying the shortcut method was an easier method. And its seems to be, as long as the program runs. Why won't it run?
Could be missing a few permissions that creating a shortcut isn't enough, even if it's running as admin.
Before that guide was even available I initially tried doing a bat file in the start-up folder too but that didn't work. Then I remembered task scheduler and it's been working without issue ever since.
