- 27 May 2008
- Petersfield, Hampshire
Importand / easy commands for Voice Attack (VA) are things like "Gear Up", "formation lights". I find that if it's a critical command then VA will decide not to recognise the high pitched version of my voice. Although "fek fek fek" works well for countermeasures.
But you will likely end up writing scripts in VA to do a whole startup from cold... my advice would be to just start playing and add other commands as you think they may be useful.
Also... VA is free to use with a limited number of commands, so you can see if it works for you before paying anything.
