Man of Honour
- 21 Nov 2004
The weather is horrid. But we do get some beadings at least...
All good until we get dusty rain that dries into spots.
That is the worst. Really hate when that happens..All good until we get dusty rain that dries into spots.
Decent deal on Autobrite 12 bottle collection.
So I was this on a well.known chinesse shopping site and thought to myself that looks suspiciously like an mjjc foam canon lance except the bottle is different. so for £14 I bought one it arrived the other day and for £14 it's remarkably well built has all the functions of the mjjc can have vertical or horizontal spray patterns. doesn't have the mjjc foam creator filter but might do a test and replace it with one. what's people's thought have a bought a clone that's made in the same factory for a fraction of the price.![]()
Used Autoglym Polar Blast followed by Polar Wash agitated with a wash mitt then finished off with Polar Seal. First time I've tried using all three on my M340i and it certainly worked a treat.
Only 'before' images at the moment as the light started to fade as we progressed into the evening.
Guys, I was using Autoglym Polar Shield again today and had a thought. I assume its an idea not to spray your alloys with it in case it gets on the brake discs? It says on the container that after its dried off you should clean the glass with glass cleaner to prevent smearing. I assume its sensible therefore, to avoid directing the spray at your wheels/brakes? I have been doing exactly that (avoiding the wheels) so far but sometimes you can't help a little overspray.
Ta.
I would make an effort to avoid spraying them, but not end of the world if you do![]()
