Probably the easiest upgrade you can do. Unfortunately nobody on our list has done a like-for-like 5800X/5700X to 5800X3D comparison.Would it be worth replacing 5800x with 5800x3D for F4? I get drops into mid 20's downtown Boston, especially around the USS Constitution. With RTX3070.
So that puts you in 2nd last (my old i5 3570K is still the lowest even below the APUs.Well. Moved from a 1080 to a 6800 and noticed 0 increase in performance in F4 on a 4770k @ 4.0Ghz. I know. Ancient CPU. Yet see a 2x increase (the delta I was buying at) in CyberPunk.
32GB PC3-17100 DDR3 2133.
11700 -- 40fps.
8000 -- 47fps.
I'm trying not to build a Starfield...rig before it comes out.
Using this table to buy my next CPU as I play a lot of F4. Thanks for getting this all together.
Thanks for posting your resutls.Is it my crappy single rank RAM?
Some confoundingly subpar results to report.
CPU: Core i9-9900K @ 4.8 GHz GPU: RTX 3080ti
RAM: 32GB (4x8GB) DDR4 3200MHz OS: Windows 10 64bit
Corvega- Draw Calls: 11040 FPS: 62.4
Diamond City- Draw Calls: 8105 FPS: 78.4
That puts you at the new #1 slot:13600k P core @ 5.8Ghz E core @ 4Ghz
DDR4 2x16GB dual rank @ 4133Mhz CL15 tuned.
Hyperthreading disabled.
3060ti
3060ti
I can do a highly tuned 7950x3d run when i get around to it, hopefully this weekStill waiting for Zen4 3D results - me and CAT have already begged on the Zen4 3D thread a few times but no luck so far.
Thanks in advance.I can do a highly tuned 7950x3d run when i get around to it, hopefully this week
I know, i'm "Det0x" from you leaderboard aboveThanks in advance.
The instructions are in the OP. Not the easiest benchmark but not the hardest either.
It's windowed at 480P or so, so if you have trouble reading the output (you have to try and match the drawcall count we all use) then switching to a lower desktop resolution might help.
(#1 with regular Zen3 and Zen4)Number One on the leaderboard!13600k P core @ 5.8Ghz E core @ 4Ghz
3060ti
User: domdtxdissar/Det0x
7950x3d PBO CO
6600MT/s tight timings, 2166mhz FCLK --> same memory settings as shown here: https://imgur.com/a/PTDq9Sl
SMT disabled
3090
Both CCD's enabled and "24/7 settings".
Corvega- Draw Calls: 7993 @ 167.2 FPS
Diamond City- Draw Calls: 11719 @ 134.8 FPS
Fallout 4 CPU benchmark thread(need some Zen3 and Zen4 results!) - dual CCD results
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
CCD1 disabled, 106 baseclock
Corvega- Draw Calls: 7999 @ 178.6 FPS
Diamond City- Draw Calls: 11701 @ 141.9 FPS
Fallout 4 CPU benchmark thread(need some Zen3 and Zen4 results!) - single CCD results
There you go: way at the top:User: domdtxdissar/Det0x
7950x3d PBO CO
SMT disabled
3090
