Sad panda today, got a 13900KF through the post instead of the KS. Guess that's what you get for ordering over the phone?
Why would you order a CPU over the phone, when the website is available?
Easily both my 13900K / KS's run that without issue.So guys, should I expect to be able to hit 6GHz single threaded on cinebench r23 at stock on a 13900KS?
Looks like I got a dodgy cpu then, mine just won't do it. It'll try, but will flick back and forth between 5.6 and 6... I'm running ACLL 0.1 DCLL 1.05 which has to be done to even run the multicore bench without hitting 100c and throttling. I'm beyond dissapointed.Easily both my 13900K / KS's run that without issue.
I worded my original statemently poorly, should it be able to maintain it? Mine flicks back and forth.Easily both my 13900K / KS's run that without issue.
LLC 4, Arctic freezer II 420mm with TG frame and LANCOOL III @RSR The bios says 1.607v for 6GHz@ L4, I don't know if that is relevant. Everything is stock other than the settings I mentioned, with enforced limits. I haven't changed to by core or anything like that, that's auto.
Ah okay, I misunderstood how it worked! I thought one core would just stick to 6GHz, didn't realise it bounced it around the coresYes, it will jump around between cores but on the whole it should maintain it.
Really tempted to pick up a 13700k to replace the 12700k but is it worth it for gaming at 1440p?
Tempted by this myself to replace my 12600k but im on a ddr4.
You’re totally fine being on ddr4. Just tune it north of 4000 daily and you’re good.
So paired with something like a 4400mhz kit.
