- 21 Dec 2019
- Planet Thanet
Thanks Will look laterin bios....
AMD Overclocking > PBO Setting > Max CPU boosh clock override (set enable plus or minus) > adjust in 50mhz steps
So if you set Enable Negative / 200, it should be 200mhz below the MAX pbo will try to boost. it dose and doesn't work lol
my cpu boosts to 4.85Ghz if i set negative 200 when it not under load i still see spikes to 4.85 but then you load up the chip with games or cinebench the max clock is 4.65
Not that a 5950x is slow lol
But there's definitely room to improve my all core boost
Especially given the motherboard is a beast so should overclock well
