I've only just noticed that I'm in a phase 2 area for CityFibre. It could still be a few years away but should be plenty of competition here soon enough as OpenReach and GrainConnect have also planned FTTP builds.
It did look like congestion but it started and stopped at near enough the same time as everyone else’s. This is a typical day for for my VM connection (yesterday). Was playing an online game from 8-11pm, always seems to make the average latency line a bit thicker.That looks like docsis (local node) style congestion, if its a routing issue, typically you would see the base line latency increase and the yellow (peak) less spiky. like johnno and @xb8browney graphs.
I can confirm my VM graph on Tuesday was fine.
Its usually in Modem mode. I've currently (as of an hour ago) got it in router mode as virgin have asked me to strip back the network to just VM hub4 and conect via that@mattyg BQM only works if you disable the firewall of the virgin router (assuming you're not using it in modem mode)
Whilst you're VPNing, surely your BQM is just quality checking your VPN provider's server?
No, the BQM will still be pointing at the WAN IP of the VM Hub which won't change when the VPN is up.Whilst you're VPNing, surely your BQM is just quality checking your VPN provider's server?
The IP is visible so I checked and it's hosted by M247 so it was just the VPN server.No, the BQM will still be pointing at the WAN IP of the VM Hub which won't change when the VPN is up.
Make sure that respond to ping requests is enabled in whatever router you are using.Its usually in Modem mode. I've currently (as of an hour ago) got it in router mode as virgin have asked me to strip back the network to just VM hub4 and conect via that
Should I have blocked that out..D'oh. I didn't notice the IP address shown on the BQM.
Am I going to get cloned now.
Lose my house
My wife and my hair..
Ok hair already gone. And the wife seems to be sticking around too...
Does it not go via virgin media firstHere though, it's been very useful as it shows that this BQM:
is pointless. It's pointing to the VPN server so isn't looking at anything to do with your Virgin Media connection.
When you turn on a vpn, all traffic on your computer goes through VM to your VPN server then to the wider web and all sites only see the vpn server ip.Does it not go via virgin media first
I've no idea how it works.
Using a vpn didn't help get around traffic shaping back in the day. I assumed it still went via virgin
Are they doing that yet.Anyone on here seeing the 100Mbps upload speed yet on a residential package?
I haven't even got the 3.1 channels on my upstream according to my Hub5 and I'm in a relatively new area with RFoG.
