Hope not.
Just for reference, I've not encountered any problems (so far), with these drivers.
Rebooted and no more issues. I'll keep an eye on this!
Hope not.
On 531.41 I seems to be getting artefacts on Desktop and in Dead By Daylight :/
Hoping it's not a dying card, 3090.
The driver overhead will never be fixed. Nvidia can't fix it..Vulkan Beta Driver 531.46 has been excellent in the games I play... Although the Latency issue is still there
Try them and let me know! - Cheers
This one's annoying, it's destroying immersion, can run it on an older driver and it doesn't crash but you can walk into a new area and it will have artifacts in it.Nvidia have acknowledged the crashes on 30 Series GPUs
- [The Last of Us Part 1] Game may randomly crash during gameplay on GeForce RTX 30 series GPUs [4031676]
NVIDIA has released a software security update display driver for desktop Kepler-series GeForce GPUs which are no longer supported by Game Ready Drivers. This update addresses issues that may lead to multiple security impacts.
Hopefully NV/devs fix it soon.
it. just. works.After my screen wakes from sleep it takes about 30 seconds for anything to work, like its frozen.
LG 165Hz.
Nvidia's perfect drivers just working?
Vulkan Beta Driver 531.54
Windows Download:
Hmm will test see if it fixes the Last of Us crashes
No, same ****![]()
i also add the nvcontainer to install, no nvidia control panel on right click option otherwiseJust did a DDU uninstall to completely wipe all the previous rubbish including any Telemetry/Geforce Experience and then used NVSlimmer to only install the core/driver and physx! Will give Last of Us a test tomorrow![]()
NVSlimmer is very convenient for removing the bloat and just installing what you want. I use it everytime.Just did a DDU uninstall to completely wipe all the previous rubbish including any Telemetry/Geforce Experience and then used NVSlimmer to only install the core/driver and physx! Will give Last of Us a test tomorrow![]()
FYI my crashes with Last of us was not driver related but page file
had 2GB pagefile for many years on 32GB RAM/3090(24GBVRAM)
but last of us used 2GB pagefile before Those, increased to 6GB no more crashes. silly really but worth a try @Neil79
