I pulled this together
List the parts please or add your parts to your basket , then press the BB code button on the basket page.
A pop up box will appear, copy the contents of the box and paste it here.
£360 (incl. VAT)
£260 (incl. VAT)
£160 (incl. VAT)
£155 (incl. VAT)
£135 (incl. VAT)
£127 (incl. VAT)
Would take a 7900xt over the 6950 xt it's 7% faster on average plus your Paying a £250 premium for that cooler on the 6950xt.
Psu is new 3.0 standard for the same price
Memory 6000mhz with tighter trimmings, cheaper with RGB bling :D
Yea the cooler is why I wanted it. I'm not confident enough to do watercooling . I see what you mean with the speeds but there's no other water-cooled gpu equivalent.
I might swap out the psu though that's a good shout.
What's the difference on the new 3.0 psu
If you want a fancy watercooler on your gpu then go for it nothing wrong with it but your in 7900 xtx Territory, I'm just giving you value options .
The atx 3.0 can deliver more power down a single cable like the 12 pin on Nvidias latest cards, I know that's not relevent with an AMD GPU but it's gives you that option in the future .
I've asked to swap the psu on the order . Thank you very much for insight.
They won't ship everything until the case and the cpu cooler are in stock anyway so I have time to look at the gpu .
Just need to know when the fractal case and the cooler will be available
I have just put a build order in and after receiving some great advice from the guys here (mickyflinn) went through a few changes for performance increase and value for money such as the PSU and GPU. My build is below and while l didnt choose the case l really wanted in the end it was a small price to pay for the best components, as in the end budget was creeping a little too much lol. The prices arent listed but the spend is very ballpark at 2.6k, the GPU advice in particular is worth it as for me you really are into 7900xtx territory as mickyflinn mentioned.
I also opted for a motherboard that has PCIE 5 for GPU and M.2 in the interests of future proofing, l see the motherboard is £70 more expensive than your choice but in my opinion will be worth it. Ah to heck with it lm going to price up my build lol.
Phanteks Eclipse G360A + rear exhaust fan
Ryzen 7 7700X
Asus ROG Strix B650E-F Gaming WIFI
Corsair Vengeance EXPO 32GB (2X16GB) DDR5 PC5-44800C36 6000MHz
Aerocool Mirage L360 ARGB Performance CPU Water Cooler - 360mm
Sapphire Radeon RX 7900 XTX Pulse 24GB
WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive
be quiet! Pure Power 12 M 1000W ATX 3.0 80 Plus Gold Power Supply
Ah the case, memory and psu arent on the configurator but the build is somewhere between 2.6k to 2.7k, hope this helps in some way!
Edited to add, as l mentioned before l was all about future proofing especially when l was dropping 2k+ on the PC. I had originally intended to spend around 2.2/3k which dont get me wrong would have been a great PC, however the extra few hundred spend got me the am5 build, pcie 5 motherboard, 7900xtx and in the end a PC that will last for at least a few years in its current config. A big sway for me on the GPU was the xtx having 24GB of vram which seems to be the way a lot of games are going to be gobbling up. The AMD drivers dont seem to be the best at the moment from what l read on the web but improvements are being made.
I ended up changing out the GPU as it wouldn't fit in the case properly
this is the end result, just have to wait for the case
My basket at OcUK:
Total: £2,980.82 (includes delivery: £7.99)​
£360 (incl. VAT)
£260 (incl. VAT)
£24 (incl. VAT)
£22 (incl. VAT)
£23 (incl. VAT)
£20 (incl. VAT)
£360 (incl. VAT)
£260 (incl. VAT)
£24 (incl. VAT)
£22 (incl. VAT)
£23 (incl. VAT)
£20 (incl. VAT)
The motherboard is EATX the case you want only supports up to ATX your going to have to change one of them.
Its a mistake on the website. Its actually a standard atx board. I rang and checked
Thanks for the insight micky, looking forward to building my adult lego set now
I'd be getting a Zotac 4080 @ £1100, and a Phanteks P600S case instead.
I do like the phanteks cases. My current build has a phanteks cpu cooler and its amazing quality
I'm a suckered for this new wood look case from fractal and I especially like the mesh side panel with dual intake fans. I'm a big proponent of the cooler a system is the longer it'll last and my current build its 10 years old and going strong so I wanted the side fan action .
The cpu rad is going in the front so no real airpow from there. Instead I'll pull in from the side and vent out the top and back. That should vent the gpu heat and keep the ram and capacitors cool.
That's good then , it's a beautiful case and don't forget to post a pic when your done
Enjoy.
Ni
Ryzen 7 7700X
Ce build very similar to what I ended up with for the same reasons.
Ryzen 7 7700X
Nice build very similar to what I ended up with and for the same reasons.
Just not to make new post. Has anyone tried this Vulcan 6000MHZ c30 ram with am5 board? I have got some G Skill Flare X5 6000Mhz EXPO C32 on order but it seems I am not receiving them till at least next week. I could simply cancel my order and pop in tomorrow morning and grab MSI B650 Tomahawk Wifi and that RAM instead. Going to put Ryzen 7900 (65W) one inside.
Nothing is gauranteed to work unless it's on the motherboard QVL list but most ram do work, if that's what's holding you build up then I would go for it.
Thats why I am asking if anyone using them with B650 board and it runs at 6000mhz and c30 or 5800 c30. Just see if anyone got first hand experience.
Edit just checked memory support list and this ram seems to be there.
