- 19 Oct 2002
- Shakespeare’s County
Just don’t ignore about 10-15% loss in charging efficiency…
My average over a year is about 320W/mile with the 3 performance so about 3 miles per kwh. I use the acceleration and do a lot of shortish journeys in addition to my commute.It's not really that relevant how much it costs to charge from low % to 100%, you don't drive it down to empty and then charge it back up again like an ICE car. You'd just plug it in daily and replenish what you used while you sleep and you wake up with a full charge. The cost to run depends on how many miles you do and how hard you drive it.
You should be able to get roughly 4 miles per Kwh when driven inside legal limits in the real world. Ignore any range claims from any manufacturer, WLTP is not very real world. How much do you pay for your electricity? Divide that number by 4 and you have how much it costs to drive per mile.
It is usually well worth getting on an EV tariff, you can pay as little as 10p/kwh for EV charging overnight. OVO's tariff has no impact on your normal day rate but it only covers EV charging. Octopus' rate covers your whole house usage in the cheap period but it has a higher day rate.
OVO us usually better if you don't have solar or battery storage, Octopus is usually better if you do or can offset a lot of energy use into that cheap period.
Yea its a 69 plate. It doesn't have the fancy octovalve which I think makes the biggest difference.Haven’t you have the original performance? A lot has changed since then in terms of efficiency and a new performance will go 20% further on a charge. 4 miles per kWh is realistic for a new long range, performance is less but not that much less.
As a point of comparison, the original performance has a similar WLTP rating as a new RWD car but it has 15kwh more energy onboard.
I meant octovalve. I know the heat pump is more efficient, but the valve does a load of other things as another poster pointed out so I suspect having that saves more than the heat pump (although I think they were changed at the same time so hard to check). I think for me with my shirt runs it would make quite a difference, but not enough to justify changing the car.I think you meant heat pump. The octovalve is simply part of the heat flux management system where it’s innovation is the packaging space it takes up. Not its actual function as a valve system.
.Ahh that explains it. I've seen it pop up a couple of times but it's so infrequent I can't remember what I was doing at the time.I don’t think it’s a feature of U.K. cars where limited regen is available.
Certainly my car will only apply the brakes on autopilot or when AEB kicks in (or I hit the brakes of course).
Yep no cap on commercial rates.To be fair, they probably pay 60p/kWh for their electricity if they have renewed their contract in the last year.
