Get some Wetcoat, once its on there you can just jetwash it off and not worry!
Agree on the bucket... Not sure I need that worx thingyWhat you need is a bucket and WORX WG620E.4
Sorry guys, you probably get asked this question all the time (and the OP post is somewhat old). I want to start washing my car myself (and the miss's) so what should I buy (assuming I'm starting from ZERO). I've already gone down a rabbit hole and am wondering if I should buy something like the Karcher K2 with accessory kit to start with. It even comes with a foam lance (never knew this was a thing until I did some preliminary research) so will this do me until I decide what upgrades I might want?
I've got an outdoor tap so I'm assuming I can just hook this up to that, put some cleaning solution in, and off I go?
Many thanks
You could start off with something like a generic car shampoo and rinse off with just a hose, not a pressure washer, assuming you have decent pressure from the tap.
that way all you need to start is a bucket, some shampoo, a wash mitt, and a garden hose. Then you can see if you want to do more after that, rather than jumping in spending £100+?
you could probably get a bucket, shampoo, wash mitt for under £30, and could pick them up from Halfords etc.
Depends how far you want to go, how much £ you want to spend, how much time you want to spend etc.
@exhashdotdot
if you want to start good to avoid scratches (that eyes can not see)
then in your situation, sounds like you have your own home , with a driveway, which is the best start as you can use a pressure washer to "pre soak" the car to loosen the dirt BEFORE a contact wash
so for me, i would buy :
Pressure washer
2 buckets
2 grit guards
Noodle mitt
Shampoo
Bilt Hamber touchless (for pre soak with pressure washer)
MJCC Foam Cannon
Wheel Brush
i need to post links for them , some you can get away with cheap, like noodle mitt and buckets
I've recently taken to parking the Crown somewhere different to usual to avoid this... The E30 can stay in the usual spot though, the paint is already beyond a lost cause.Grr just moved my car into the driveway after leaving it across the road for 24 hours while family members visit. It's covered in bird **** and fluffy seed/leaf things. I'm not super precious about the car or paintwork (2003 Yaris MPV, it's a workhorse) but it was all over the door shuts/edges, handles, and glass. Driving 2 hours tonight so need to be able to, er, see. Only got kitchen roll and Windex as I'm renovating this house so that's what I used!
Note to self, never park under that tree. Smug ******* is still tweeting from up there.
If it is proper grim stuff I would lay kitchen roll over it and soak it in Windex and let is rest for a bit.Grr just moved my car into the driveway after leaving it across the road for 24 hours while family members visit. It's covered in bird **** and fluffy seed/leaf things. I'm not super precious about the car or paintwork (2003 Yaris MPV, it's a workhorse) but it was all over the door shuts/edges, handles, and glass. Driving 2 hours tonight so need to be able to, er, see. Only got kitchen roll and Windex as I'm renovating this house so that's what I used!
I just had to fully dive in and get mucky before the sun went down... Amazingly my girlfriend came and helped, she's never cleaned my car in 10 years!If it is proper grim stuff I would lay kitchen roll over it and soak it in Windex and let is rest for a bit.
Hardcore - bit of petrolBest Tar spot remover please?
I bought Gtechniq W7 Tar and Glue Remover but not finding its very good at shifting Tar spots at all!! Anything else I should get instead please anyone??
