- 21 Jul 2005
- Officially least sunny location -Ronskistats
The 4070 is essentially a 4060 or Ti in anything but name.
With a lovely nvidia greed tax on top.
At this rate even a A770 16GB is going to be better than a 4060 and cheaper, with more vram.
The 3080 aged well because it delivered that level of performance 2.5 years ago but it is struggling now especially at 4k, imagen how poor the 4070 will look in 2.5 years with it only delivering the performance of what will be a 5 year old 3080 by then.Is 10gb enough in 2023? steve says yes and he would take one over the 6800xt at similar price. 4070 has made them both obsolete at £500 or more.
I saw this posted on TPU:
| GPU | Branding | Cores | % of Top die | Bus | Bandwidth | MSRP |
| GP102 | AD102 | 3840 | 100% | -- | -- | 2017 had Titan xP release with the full die at $1,200 |
| GP102 | Titan X | 3584 | 93.3% | 384 bit | 480.4 GBps | $1,200 |
| GP102 | 1080Ti | 3584 | 93.3% | 352 bit | 484.4 GBps | $699 (2017 release) |
| GP104 | 1080 | 2560 | 66.67% | 256 bit | 320.3 GBps | $599 |
| GP104 | 1070 | 1920 | 50% | 256 bit | 252.3 GBps | $379 |
| GP106 | 1060 6GB | 1280 | 33.3% | 192 bit | 192.2 GBPs | $299 |
| Branding | Cores | % of Top Die | Bus | MSRP | Performance |
| 4090 | 16384 | 88.9% | 384 bit | $1,599 | 4090 |
| 4080 | 12288 | 66.67% | 256 bit | $799 | Between current 4080 and 4090. |
| 4070 | 9728 | 52.8% | 256 bit | $599 | about current 4080 |
| 4060 | 6144 | 33.3% | 192 bit | $399 | about 3080 / current 4070 |
GPU Branding Cores % of Top die Bus Bandwidth MSRP GP102 AD102 3840 100% -- -- 2017 had Titan xP release with the full die at $1,200 GP102 Titan X 3584 93.3% 384 bit 480.4 GBps $1,200 GP102 1080Ti 3584 93.3% 352 bit 484.4 GBps $699 (2017 release) GP104 1080 2560 66.67% 256 bit 320.3 GBps $599 GP104 1070 1920 50% 256 bit 252.3 GBps $379 GP106 1060 6GB 1280 33.3% 192 bit 192.2 GBPs $299
If we add in Pascal as well we get a similar story. 1060 has 33.3% of the the full die shaders and matched the 980. The 1070 is around half the shaders of the full die variant and the 1080 was around 66%. Titan X is a bit better than 4090 but the refresh 1080Ti took that spot at a lower price point and Titan xP took the $1,200 spot in 2017.
If that had been followed you would get something like this.
Branding Cores % of Top Die Bus MSRP Performance 4090 16384 88.9% 384 bit $1,599 4090 4080 12288 66.67% 256 bit $799 Between current 4080 and 4090. 4070 9728 52.8% 256 bit $599 about current 4080 4060 6144 33.3% 192 bit $399 about 3080 / current 4070
That stack would be in line with the historical stacks and pricing is basically 2000 series pricing which was a bit higher than 3000 series at each tier and allows for inflation / higher costs while not totally screwing the customer.
Time to jump over to Mama Su!It's the same move Nvidia tried with Turing. Street prices of their dGPUs shot up as miners bought everything they could find. Then PCMR also paid those prices too. Then Nvidia was left with a lot of unsold Pascal stock,didn't want to discount it and liked the new higher street prices. This is exactly the same but even worse in all metrics.
After the last driver update it pretty near a 3060 Ti.The 4070 is essentially a 4060 or Ti in anything but name.
but like 399 for 16gb,cheapest i found, is it a viable option, im not so sure.Intel is also making some decent driver improvements too.
but like 399 cheapest i found, is it a viable option, im not so sure.
Wait for the 7800XT, that way have more options, and a reason to procrastinate more.The LE (when it’s back in stock) is 370 which is a bit better. The performance is inconsistent, but £370 for a 16GB card with performance between a 3060-3070 isn’t too bad. The 750 is a much better buy though IMO, only 8GB and reduced specs but not a huge loss in performance and at £250 it’s very competitive.
6700/6750 are good cards, and I’ve been contemplating one. I particularly wanted the strix just for the aesthetics but at £440 you are ‘only’ £140 from a 4070 and then it goes back in to this merry go round I’ve been having in my head for the past week about what’s the best card to buy haha.
the phrase is **** or get off the potWait for the 7800XT, that way have more options, and a reason to procrastinate more.
I'm not surprised and I did wonder from reviews whether it was fair to compare with previous xx70 series but at least there's no denying it now, I suspect they've intentionally done this with the numbers to obfuscate the price hikes and make them not seem like a rip off, but given the amount of videos I'm seeing recommended on youtube and everyone ******** on the 4070 it seems people are finally seeing through team green at least those in mid range budgetsSo does this mean the 4070 is more comparable to the xx60 series in previous generations but double the price ?
Aye that’s one conclusion I keep coming to.
The 7600x has a iGPU at least so all isn’t lost on that particular pc.
Be nice if AMD were a bit more vocal I just assume they want to sell as much of the existing 6000 stock as possible before announcing anything.
How? They've pulled the same shenanigans with rebranding what should have been the $650 7800 XT to a $900 7900 XT, and they straight up lied about the performance gains. Even with the price cut to $800, theAMD is a bit better
I kept telling people on here,that the RTX4070 is really an RTX3060. Its similar to what a 60 series cards is relative to the top,and has the same memory configuration. I also pointed out that the AD104 is a third tier die,just like 106 series dGPUs.
The RTX4060TI is going to either use a severely cut down AD104 or the fourth tier AD106. The RTX3050 used either a severely cut down third tier GA106 or a fourth tier GA107. They both have the same memory configuration. The RTX3050 also increased the £150 price point of the 50 series to above £200.
People were half-jokingly saying we would get 50 series dGPUs above £300. Well here we are. All because of FOMO,which you would expect kids to have.
