Just checking with you knowledgeable lot before I pull the trigger.
I’m planning 10 panels on the garage and 4 on the outdoor bar. Panels will be 400W mono. Inverter will be a 6kw solis, with 3 x 5kw pylon batteries in a rack in the garage. Going to put in a smart car charger for the excess.
Bar is south facing, garage is south west.
At the moment I’m looking at circa 8k for the lot fitting it myself and using a solar install to finish wiring it in and certify it.
Just dipping my toes at the moment. I think cost vs kit is really strong. That said…looking towards the future I’m tempted to fill the house roof albeit that will need a serious scaffold set up which will add to cost significantly.
Should have 5.6kw of panels and 12kw of useable storage for 8k. Am I missing anything?
Id be changing that conservatory roof to a tiled roof and piling panels on there…..can use conservatory all year round than as it would be warmer in winter and not so hot in summer.
There's always these instead of Pylon batteries. They come with an 8 year UK warranty.I thought this, but it all depends when you take it - I looked at my pension fund recently and the annuity was a much better annual return now interest rates are climbing.Good job I've not got an annuity, I think most realise they are pretty poor deal these days, when I say pension its a portfolio of funds, a SIPP.
Sounds good price and sensible.
Don't forget the bird netting.
Lovely looking house btw
Yes, more panelsThere's always these instead of Pylon batteries. They come with an 8 year UK warranty.
I had this company install insulation in ours and I've also got 3.5kW air source heat pump in there(you can fit them yourself if you just put a plug on it) - much cheaper than changing the whole roof.It’s not too bad as we have a 5kw ac machine in there with two big rads which keeps it pleasant. However, my plan eventually is to replace the entire front with glass sliding doors and an insulated roof with two lanterns. The heat loss is pretty evident during the winter with the glass roof ![]()
crikey those prices look fantastic and have got me tempted........................... sorry for ignorant comment but..Yes, more panelsThere's always these instead of Pylon batteries. They come with an 8 year UK warranty.
could i buy one of those 5kwh units and hook it up to my existing system (5kw solis hybrid inverter which currently has 3x2.4kwh pylon batteries? or cant you mix and match?
And having said that I've just caught up with the thread in Diyforums. Fogstar hadn't responded to my queries direct to them the warranty issue.Only problem with hooking up Fogstar rack batteries is that it would invalidate my inverter warranty. Solis have a fairly restrictive list of batteries that are permitted.
How do you space the mounts for the rails? Roughly every 1200 enough? I assume you start where the fist rafter is and work it that way?
