Not gonna bother with my referenced cooled 6700XT that wont go above 2800-2850ish on the clock.Any chance of some competition in Timespy for the 6700 XT please folks?
enjoy the top my friend
Didn't want to helpful spam post in your MM thread and can't PM (must have it turned off) but ref: the sticker/badge you're looking for, you'll likely have more luck searching Republic of Gamers or ROG, that's what the "eye" logo is.![]()
Picked up a Strix on the cheap the other day. Will be going in my new mini rig.
Mine just arrive from OC. ROG strix 6750 XT
very quiet tooGood looking GPU that...
water block coming for itA lot of people on this forum need a bigger case![]()
well mine has horrific coil whine. Really bad TBH so its going back. Sadly as coil whine isn't considered a fault I need to pay for the return![]()
6750 XT Strix OCMake Model?
Oof..... ok, thanks![]()
was quite until the power went above idle. shame really as I was only seeing 170w max in the games I play which isn't that much more than what the 5600XT was showing.
It is a shame because its a really nice card that, especially for a bit over £400, i had my own eye on one...
What are you going to do now? get one from a different vendor?
no idea TBH.
