Speed is rarely a cause, it is a fatuous debate really. Remove the driver there would be no speed, so the driver is the cause, or the machine breaking or inappropriate speed as the hands of said driver. THAT is your cause.I've always thought the safest speed is the speed that requires the least amount of interactions with other cars ie go with the flow
Loads of deaths possible at 70mph or below, we see them sadly everyday and we lots of deaths where speed was legal. Speed, it might be argued, adds to the risk of the results of an accident being worse for those involved, but that is a dead end debate that removes the reality of transportation and the need to move people around the globe at 100's of miles per hour. We can't make life 100% safe, the world does not work that way. We have speed limits in the UK to add an element of control, but 56mph will still wipe you out if you are in the mini 1000 the lorry drives into. Put a better lorry driver in and your problem is removed by and large for that is usually the point of failure.
Speed can be dangerous in the same way as a tank in the hands of 5 year old but limited to 20 mph can wipe out a brass band. Sure, if the tank wasn't allowed to move it would be safe, but it could move at 50mph with a tank driver in it quite safely.
Speed kills is the mantra of the soundbite nation.
