fault in power socket
jcr
jcr
29 May 2011
southampton
Acer Nitro 5 lap top. about year and half old.
i mostly use it on my lap whilst sat on a chair.
now whenever i move it the charge cuts off and on if its plugged in.
it seems like the connection is loose/faulty at the point where the power lead plugs in.
is this something i can fix myself?
thanks.
thanks.
If you have to ask the question, then nope. It sounds like the power connector on the laptop may now have a dry joint. The laptop covers will need removing and the connector re-soldering. Is this something you might want to have a go at, as there are teardown vids on youtube for your model of laptop.
  • Like
Reactions: jcr
thanks for the reply. ive not used a soldering iron before but it looks easy enough. i may well give it a go.
Don't assume there's soldering involved, it may be a part you can replace cheaply. It could just plug into the motherboard - have a Google, see if there are YouTube videos or ideally an iFixit guide.
  • Like
Reactions: jcr
You would need exact model number
But a quick look suggests
It may be a plug in job no Soldering
For at least a few of acer nitro 5 models if not all
How easy it is to get to may be another question though
For dismantling laptops
I take photos and print them
Then as take screws out I tape them to the relevant place
In the photo
Since I find the biggest pain is all the different screw sizes
  • Like
Reactions: jcr
In the photo
thanks for the advice.
my model is Nitro AN517-52
can anyone advise where to buy the part?
Usually ebay I get mine
Possibly even amazon nowadays
If its a popular laptop model especially if the parts used
Across multiple models it's not hard to get one
Will also be laptop part companies
Doubt you'll have to resort to China for that model
  • Like
Reactions: jcr
turns out it was the power lead thats faulty.
£41 for a glorified plug seems a bit expensive :eek:
