- 30 Mar 2017
I have an O11D Evo Reflection 2 Distro with 2 360 radiators top and bottom with Corsair ML120 fans. Radiators all outtake seems to cool best with 3 side fans intaking and rear outtake. Cooling an RTX 4090 and Ryzen 7900x. All EK blocks.
I run the fans at 50% rpm and the D5 pump at 65%. That fan speed is the highest I can tolerate and I get 130l/hr flow and about 200 at 100% pump speed. Not much temp difference above certain pump speed.
The room temp is around 23c currently and the water temp always idles about +8c over ambient.
Under load the water temp currently gets to about 45c. Gets up to 40 within about 10 mins and creeps up slowly to settle there.
My GPU temps are the main worry getting to around 65c max at stock. Around 20c over water, which I have heard is fairly standard. The water temp just isn’t helping though. The hotspot temp is about +8 over core at idle and +15 load. Not great not terrible.
I can only get a few C cooler maxing the fans but that’s not tolerable.
I don’t think I want to try reseating the GPU. Anything else I could possibly try to lower the water temps other than AC?
Thanks.
Thanks.
